D
dubbs
Don't worry about Hatchers The 2-stroke oil is a good idea . . In fact the boondocker kits call for synthetic 2 stroke oil in their turbo
Here is some food for thought . . . These turbos were not manufactured specifically for snowmobiles, they are the same basic design as tubos found in high performance cars only smaller. Do you think it would be normal for a turbo mounted in your car to be leaking oil? If they did there would be a blue haze following every rice rocket out there.
I don't think it's normal for turbo's to burn oil but know that they are way more inclined to do so if the oil return path is blocked whatsoever... I was at a pretty steep angle and could have been bouncing the thing around quite a bit when I saw it burn that bit of oil... I think it prob just got by the seal on the turbine side... Makes sence with the angle too... I wonder if having it upside down for a half hour could have something to do with it aswell... I would think so!!!
The Comment from Dave about the "issues" has my curiosity peaked??
