every 3 rides.
1. Belly pan off, and clean entire underside of engine compartment.
(leave belly pan off)
2. Pull secondary off and clean
3. Pull pipe
4. Pull plugs and check burn
5. Check piston wash
6. Take brake cleaner and clean entire engine compartment
(do not spray directly into wire connections)
7. Check all bolts and nuts (factory, and turbo)
8. Flip sled on side again and clean belly pan area again, Make
sure to get the throttle bodies good and clean. Re-install b pan
9. Reinstall secondary and set belt up proper.
10. Check ski alignment, track tension, and track alignment
11. Grease all zerks.
12. Clean powervalves, check cables
13. Rip
I do this religous, takes most of a day, but worth every second. Your
turbo sled will appreciate the love.
I do the DD maintenance twice a year.
