Turbo heads
D
dschwindt
So I checked my compression on my 2011 pro rmk and sittin at 92 psi with 5 pulls on the rope for each cylinder. Sled still starts and runs awesome. BD turbo installed 150 miles ago. Sled now has 650 miles. End of this season I will probably change out for new pistons and was wondering about a good aftermarket head to add on at this time. Sled is running 9psi with straight avgas from elevations at 2000' to 8000'. I had also turned up the oil pump 1.5 turns as the oil usage was iffy. Question is what would be a good head to run on this setup.
Thanks
I would suggest going with the RK Tek turbo head and pistons. Not only will you get a head that is build specifically for your setup (avg elevation, boost, fuel, etc), but you also get a set of pistons that are forged, and have better tolerances than the sloppy, Cast OEM pistons.
Turbo Head.
I am going with the RK Tech drop in kit and head set up for 5000' and higher.
I have had no problems on my Boosted 2012 RMK . Just going for a more reliable piston setup and a properly designed head for turbo use.
Will only get 1 trip to test out the drop in kit if parts arrive in time. Will post again after I get 5 day ride completed.
Did you get that last ride in? thinking of getting kit and head also....
