Turbo gasp
having problems with mc turbo 1000 miles on sled , when i hit the gas it gasps and misses , once rpms are up it runs fine , happens only in the higher altitudes , climbing let of gas then hit and it just about stops before it goes again had problem from day one no one from mc wants to help need snow talk to give me some ideas. need help
hows the jetting?
The higher you go the richer it gets, the richer it gets the more turbo lag you have(to add to a crappy rich running motor), ect...
just a quick thought...
uumm what sled is this in a few more details so guys can help you
06 apex it has the 310 kit i know its get fatter but i sure this is not the problem i ride with other 310 apexs and they have no problems, efi did not know you have to rejet it will do it i a middle of a climb once you let of it run rough until you get the refs up and then it runs fine.
how many miles on it.check all your sensor lines for moister & check you header pipes to see if they are cracked or collapsing.you may need a remapping but i doubt it.
Check your grounds, it might have a weak ground causing it to momentarily miss/ Many possible things to look for, start with what we have given you and move from there. Process of elimination.
