I have had this problem forever with my BD setup and I am going to try and put the intake screen right on the turbo and get rid of the snorkel all together. In deep snow the snorkel gets covered in snow and then the sled will stall right out. I will put a screen kit over the hole in the side panel and suck from under the hood. Have a look at the intake screen that Custom Turbo Werx has for the doo kit. Hotter intake air potentially going to be any concern???
This has been tried and retried. The turbo intake hole can not pull enough air. This is hard to understand until you have tired it. Believe me, if BD could have drawn enough air without making the snorkel stick up out of the hood they would have done it. I have tried, or guys I ride with have tried every possible way of getting air from under the hood. There is a reason BD, Alpine, MCX and all the other good kits have a way to pull cold air from outside.
This is evidently a much bigger deal on the 4 strokes than the 2 strokes?
The two best solutions we have found are making the foam prefilter. This seems to work well and allows you to break the ice off as it build up. If you do this you will need to make a new external filter as the BD one will not fit over snorkel with the prefilter on there. The other thing that works on the BD kit is to extend the snorkel about 8 to 12 inches. A majority of the snow hitting the snorkel is from the skis. Raising the snorkel 8 inches seems to allow a majority of this snow to hit the extension and keeps it off the snorkel. It looks stupid, but works effectively. From my experience this is a problem with all kits in the deep powder regardless of where the intake is located. I tired to get BD to design an extendable snorkel for deep powder days but they were already out of the 4 stroke scene.
