turbo ecu update?
H
HCM
07 m1000 turbo reflash, Don't now the history on this sled but my Buddy's sled is the same sled but newer with the same kit on it and his attitude box #'s are way lower then mine and has some left to go up or down, mine are just about maxed out so thinking this thing has never been reflashed it is running fine when running I guess but would be nice to be able to richen it up some more if I need to, would it be worth it to do the reflash on the computer. Thanks.
Does the box have an option to remove fuel, if you raise the F/P it could screw you if you can't remove fuel but I run mine at 50psi and havent had to remove fuel.
Flashed it yesterday it was still stock 07 setup ran it just a bit with the same settings and could not get it to even clean up till I leaned it down a bunch so now at least I can have some room to move a bit, Running 42 psi fuel pressure at Idle.
