D
I recently picked up a 2018 pro rmk 800 with 1k miles that had a Silber turbo installed on it. Got what felt like a crazy deal on it at $6k. Now I'm not so sure.
Idle was super low, bouncing between 1500 and almost stalling at 1100. It was leaking coolant, from what looked like the MTNTK tunnel chop kit with the plastic fittings.
Compression was low; 95 Mag/105 PTO. I inspected the top end with a borescope and found bad cylinder scoring and head/piston damage on the mag side. Looks like some debris got sucked in and bounced around. There was still bad scoring on the PTO side, but no debris damage. Haven't looked at the reeds yet.
I'm going to replace the top end, cylinder included. Was able to polish down the head and I think it is salvageable. I want to make sure I'm getting to the root of the issue though.
Does anyone have any ideas on what could have caused this? Debris coming through turbo for mag side? Water ingestion? There was no sign of anything missing in the top end; piston clips were there, needle bearings all intact, no sign of damage on the bottom end.
What about the scoring on the PTO side? The tunnel was chopped with the MTNTK plastic kit, which was leaking, and I have a feeling this guy was running the sled way too hot.
Think I am going to weld in the CR Racing cooler kit rather than try to fix the leak in the MTNTK kit. Thing is, there was some coolant pooling near the hoses under the fuel tank, and some drips coming down from the middle of the bottom of the tunnel after a couple minutes of running. My thought was the coolant was just dripping down under the tunnel from the chopped end, working its way through the riveted seams, but is it possible that there is a leak in the tunnel body itself?
New to sleds, but not to general mechanic work. Any and all help or thoughts is appreciated.
