Turbo Apex clutching questions?
Guys, Id really appreciate some input on this subject. I'm putting a rear mount Bender turbo on my Apex next week. I plan to run between 8 and 10lbs boost. I want to get the clutch taken care of before the kit gets here. I run a camo extreme 162x2.5x16 track and run at mostly 4-7000 feet in elevation. Mountain riding. What are you guys running for clutch setups and where is a good place to get the parts? Any input would be appreciated.
Supertips clutch weights from Supreme Tool and Machine, Shockwave helix with a black arctic cat secondary spring.
As for weights in the primary, i wouldnt know with lower boost levels but start around 75 or so grams total weight. Just a guess but others might be able to set you up a little closer.
