Tunnel Dump Questions
n2otoofast4u
Im wanting to get away from my muffler setup and go to a tunnel dump. Are there any do and don't tips that I should be aware of? Seems pretty simple in theory but maybe its not in reality? When I run my sled without the existing muffler the O2 sensor is about a half inch from the end of the pipe and the gauge is really erratic. Im assuming this will smooth after I extend the pipe down? Was thinking of cutting and starting from about where my finger is. Good idea or no?
Was figuring to put the sensor in about that location as well. Acceptable? Can the pipe enter the tunnel angled or does it need to be 90 degrees? Flush with top of tunnel or how far extended in? Any help is appreciated.
Here's my existing setup. Its 9 pounds. Just trying to simplify and save some weight.
I just did..
I just did one of these tunnel dump mods on that same side exit system in the shop last week.
Order a 3" mandrel bent 90 degree pipe section from an Auto supply or Muffler shop. It needs to be mandrel bent with a tight radius.
Pull the 3 springs and remove the muffler and pipe. Cut off the connection flange directly where it enters the muffler, use a zip style cutoff wheel on grinder, cut tight to the muffler and be careful not to jam it. Put the flange section back onto the discharge pipe with springs in place. Hold your mandrel bend piece in place to determine lengths and where to cut. Visualize where you want the hole to exit through into the tunnel, slightly right of the center located coolers, approximately 1/2" in from outer edge of tunnel. Mark the hole location. Cut out the hole. Again hold your mandrel bend in place and re-estimate the length for cutting.
It is pretty straight forward, just measure twice cut once. Straight 90 degree to the pipe cuts worked well for me. Leave the exit end about a half longer to extend down into the tunnel a half inch.
I welded new supports for the heat shield onto the new pipe section so it was retained in the original location. Also wrapped the new pipe with 2" heat wrap. approximately 6' long. Wired the heat wrap in place.
Order a new side panel from your Yamaha dealer and project complete.
**the mandrel bend is the key, if you try to bend 3" pipe that tight it well crease and kink up.
Good luck!!
