The middle insert between the two coolers seems to be of softer aluminum on the new pro's vs. the IQ chassis. This is what I believe the issue is.
Same aluminum... The Pro RMK just has a much wider center section between the coolers.
IMO...If it really bugs you... rivet a section 1/8" HDPE or UHMW down the center section between the coolers in the rear... If you do it carefully it will look "factory installed" and not detract from the sled.
