TSS bottoming out? What will I bend?
My google fu has failed. I am installing a TSS in a KX500 and it looks like the subframe travel is ultimately limited by the Timbersled subframe hitting the Kawasaki subframe, if I don't mount anything else in the way.
Is the shock progressive enough this doesn't happen in normal use?
Many thanks for any input!
You should adjust air pressure in the tss to limit travel to about 1 1/8" I believe.
To answer your question - if they make contact the timbersled frame will bend you bikes subframe.
