sleds
= Failure Mode Indicator
MIL Status: ON = Check Engine LED Illuminated
Trouble Code
SPN
FMI
P-CODE
MIL STATUS
Condition
Throttle Position Sensor 1 51 3 P0123 ON This Trouble Code sets if the Throttle Position Sensor Signal is above 4.39 Volts.
Can be caused by Damaged Wiring, a faulty Throttle Position Sensor or ECU / Connections.
4 P0122 This Trouble Code sets if the Throttle Position Sensor Signal is below 0.7 Volts.
10 P0120 This Trouble Code sets when the Throttle Position Sensor Signal changes too rapidly to be correct. The condition can be caused by intermittent connections causing the TPS voltage to jump around between readings. Check for damaged connectors or wiring.
Vehicle Speed Signal 84 2 P0503 This Trouble Code Sets if the Vehicle Speed Signal is intermittent or missing.
Can be caused by Damaged Wiring/Connections or a Faulty/Loose Vehicle Speed Sensor
Engine Oil Level Sensor / Switch 98 17 P250F OFF This Trouble Code Sets if the Oil Level is Too Low.
Can be caused by Low Oil Level, a faulty Oil Level Sensor or Faulty ECU/Connections.
Intake Air Temperature Sensor 105 3 P0113 ON This Trouble Code sets if the Intake Air Temperature Sensor Signal is above 4.9 Volts.
Can be caused by Damaged Wiring, a faulty Intake Air Temperature Sensor or ECU / Connections.
4 P0112 This Trouble Code sets if the Intake Air Temperature Sensor Signal is below 0.19 Volts.
Barometric Pressure Sensor 108 3 P2229 ON This Trouble Code Sets if the Barometric Pressure Sensor Signal Circuit is Open or Shorted to Battery Voltage.
Can be caused by Damaged Wiring/Connections, a Faulty Ambient Pressure Sensor or ECU
4 P2228 This Trouble Code Sets if the Barometric Pressure Sensor Signal Circuit is Shorted to Ground.
10 P2230 This Trouble Code sets if the Barometric Pressure Sensor Signal indicates an Unrealistic Rate of Change.
Can be caused by Damaged Wiring, a faulty Barometric Pressure Sensor or ECU / Connections.
Engine Temperature Sensor 110 3 P0118 ON This Trouble Code sets if the Engine Coolant Temperature Sensor Signal is above 4.8 Volts.
Can be caused by Damaged Wiring, a faulty Coolant Temperature Sensor or ECU / Connections.
4 P0117 This Trouble Code sets if the Engine Coolant Temperature Sensor Signal is below 0.1 Volts.
0 P1217 OFF This Trouble Code sets if the Engine Temperature indicates a Critical Over Temperature Condition and the engine is running in a limp-home mode to prevent damage.
Can be caused by any failure that would cause the engine to overheat.
16 P0217 This Trouble Code sets if the Engine Temperature indicates a Severe Over Temperature Condition.
Can be caused by any failure that would cause the engine to overheat. This Trouble Code Does Not indicate a problem with the Engine Temperature Sensor.
15 P1116 This Trouble Code sets if the Engine Temperature indicates an Over Temperature Condition.
DC Chassis Voltage 167 3 P1569 ON This Trouble Code sets if the System Voltage is above an acceptable level.
Can be caused by Damaged Wiring, a Faulty Voltage Regulator or Faulty ECU.
4 P1568 This Trouble Code sets if the System Voltage is below an acceptable level.
Can be caused by Damaged Wiring, a faulty stator, Faulty Voltage Regulator or Faulty ECU.
Exhaust Temperature Sensor 173 3 P0546 ON This Trouble Code sets if the engine has been running above 3000 RPM for more than 2 minutes and the Exhaust Temperature Sensor Signal is above 4.90 Volts.
Can be caused by Damaged Wiring, a faulty Engine Temperature Sensor or ECU / Connections.
4 P0545 This Trouble Code sets if the engine has been running above 3000 RPM for more than 2 minutes and the Exhaust Temperature Sensor Signal is below 0.06 Volts.
0 P1517 This Trouble Code Sets if the Engine was Shut Down due to High Exhaust Temperature.
Can be caused by a Faulty Exhaust Temperature Sensor/Connections or Lean Air/Fuel Ratio causing high exhaust temperature.
ECU Memory Checksum Error 628 13 P0601 OFF This Trouble Code Sets if an Internal Memory Fault is detected in the Engine Controller
Can only be caused by a defective ECU.
Crankshaft Sensor Signal Fault 636 2 P0335 OFF This Trouble Code sets if the Engine is Running and No Signal is Detected from the 5X Crankshaft Sensor.
Can be caused by Damaged Wiring, a faulty Crankshaft Sensor or ECU / Connections.
Crankshaft Position Sensor Circuit Fault 636 8 P0336 OFF This Trouble Code sets if the Engine is Running and the number of pulses from the 5X Crankshaft Sensor is not correct.
Fuel Injector (MAG) 651 5 P0261 ON This Trouble Code sets if an Open Circuit Condition is detected in the MAG Cylinder Port Injector Control Circuit.
Can be caused by Damaged Wiring, a faulty Fuel Injector or ECU / Connections.
3 P0262 This Trouble Code sets if a Short to Voltage is detected in the MAG Cylinder Port Injector Control Circuit.
Fuel Injector (PTO) 652 5 P0264 ON This Trouble Code sets if an Open Circuit Condition is detected in the PTO Cylinder Port Injector Control Circuit.
3 P0265 This Trouble Code sets if a Short to Voltage is detected in the PTO Cylinder Port Injector Control Circuit.
Knock Sensor 731 4 P0327 ON This Trouble Code sets if the Engine Speed is above 6000 RPM and the Detonation Sensor Signal is below 1.23 Volts for more than 2 seconds.
Can be caused by Damaged Wiring, a faulty Detonation Sensor or ECU / Connections.
2 P0325 This Trouble Code Sets if the Knock Sensor Signal indicates an Unrealistic Value.
Can be caused by a Faulty Knock Sensor/Connections, a Loose Sensor or Excessive Engine Mechanical Noise.
Ignition Coil Primary Driver (MAG) 1268 5 P1351 ON This Trouble Code Sets if the Ignition Coil Driver Circuit is Open.
Can be caused by Damaged Wiring/Connections, a Ignition Coil or ECU
Fuel Pump Driver Circuit 1347 5 P0230 ON This Trouble Code Sets if the Fuel Pump Relay Driver Circuit is Open.
Can be caused by Damaged Wiring/Connections, a Faulty Fuel Pump or ECU.
Knock (DET) Level (MAG) 1352 0 P1336 ON This Trouble Code Sets if the Engine Controller Reaches the Maximum Detonation Control Limit by Fuel Correction on the Mag Cylinder
16 P2336 This Trouble Code Sets if Cylinder 1 (MAG) Knock Sensor reaches a Critical Level. Can be caused by Excessive Knock (Fuel Problems), a Lean Running Condition or Engine Mechanical Problems.
Knock (DET) Level (PTO) 1353 0 P1337 ON This Trouble Code Sets if the Engine Controller Reaches the Maximum Detonation Control Limit by Fuel Correction on the PTO Cylinder.
16 P2337 This Trouble Code Sets if Cylinder 2 (PTO) Knock Sensor reaches a Critical Level. Can be caused by Excessive Knock (Fuel Problems), a Lean Running Condition or Engine Mechanical Problems.
Sensor Supply Voltage 1
(TPS / TMAP) 3509 4 P06B1 ON This Trouble Code sets if the Sensor Supply 1 Voltage is below an acceptable limit (4.50 Volts). Can be caused by Damaged Wiring or Faulty/Shorted Sensors.
Sensor Supply Voltage 2
(Speed Sensor) 3510 4 P06B4 OFF This Trouble Code sets if the Sensor Supply 2 Voltage is below an acceptable limit (4.50 Volts). Can be caused by Damaged Wiring or Faulty/Shorted Sensors.
Electronic Oil Pump 3589 5 P16BA ON This Trouble Code Sets if the Oil Pump Driver Circuit is Open.
Can be caused by Damaged Wiring/Connections, a Faulty Oil Pump/Connections or Faulty ECU/Connections.
12 P16BC This Trouble Code Sets if a Failure is Detected in the Oil Pump Driver Circuit.
ECU Output Supply Voltage
Fuel Injector Power (16V) 3598 3 P16A9 ON This Trouble Code sets if the Injector Output Supply 2 Voltage is above an acceptable limit. Can be caused by Damaged Wiring or Faulty/Shorted Connectors.
4 P16A8 This Trouble Code sets if the Injector Output Supply 2 Voltage is below an acceptable limit. Can be caused by Damaged Wiring or Faulty/Shorted Connectors.
Ground Speed Sensor (5V) 3599 3 P17AA ON This Trouble Code Sets if the ECU Output Supply Voltage #3 (Vehicle Speed Sensor Supply) is Too High. Can be caused by Damaged Wiring/Connections, a Faulty Vehicle Speed Sensor/Connections or Faulty ECU/Connections.
4 P17AB This Trouble Code Sets if the ECU Output Supply Voltage #3 (Vehicle Speed Sensor Supply) is Too Low. Can be caused by Damaged Wiring/Connections, a Faulty Vehicle Speed Sensor/Connections or Faulty ECU/Connections.
Throttle Release Signal 520194 3 P1555 ON This Trouble Code Sets if the Throttle Release Switch Signal is Open Circuit or Shorted to Battery Voltage. Can be caused by Damaged Wiring/Connections, a Faulty Throttle Safety Switch or ECU.
4 P1554 This Trouble Code Sets if the Throttle Safety Switch Signal is Shorted to Ground. Can be caused by Damaged Wiring/Connections, a Faulty Throttle Safety Switch or ECU.
7 P1552 This Trouble Code Sets if the Throttle Release Switch Signal Indicates a Throttle Stuck Open. Can be caused by a Stuck Throttle or Mis-adjusted /S tuck Throttle Linkage.
Exhaust Valve Solenoid
(600 Only) 520215 5 P1477 ON This Trouble Code sets if an Short to Voltage Condition is detected in the Exhaust Valve Solenoid Control Circuit. Can be caused by Damaged Wiring, a faulty Exhaust Valve Solenoid or ECU / Connections.
3 P1479 This Trouble Code sets if an Short to Voltage Condition is detected in the Exhaust Valve Solenoid Control Circuit. Can be caused by Damaged Wiring, a faulty Exhaust Valve Solenoid or ECU / Connections.
Load Shed Relay 520219 5 P1646 ON This Trouble Code Sets if the Load Shed Relay Driver Circuit is Open. Can be caused by Damaged Wiring/Connections, a Accessory Ignition Relay or ECU.
3 P1647 This Trouble Code Sets if the Load Shed Relay Driver Circuit is Shorted to Voltage. Can be caused by Damaged Wiring/Connections, a Faulty Accessory Relay or ECU.
Battery Charge Relay
Battery-Equipped Models Only 520220 5 P163C ON This Trouble Code Sets if the Charge Relay Driver Circuit is Open. Can be caused by Damaged Wiring/Connections, a Charge Relay or ECU.
3 P163D This Trouble Code Sets if the Charge Relay Driver Circuit is Shorted to Voltage. Can be caused by Damaged Wiring/Connections, a Faulty Charge Relay or ECU.
Oil Pump or Fuel Injector Settings Not Programmed 520241 13 P1278 ON This Trouble Code Sets if Either the Fuel Injector or Oil Injection Pump Calibration has Not Been Programmed. Update the Injector/Oil Pump Settings.
WARNING: Do Not Operate the Vehicle with This Trouble Code Set.
Ground Speed Pulses per Mile Not Programmed 520242 13 P1279 ON This Trouble Code Sets if the Vehicle Speed Sensor Setting is Not Properly Programmed in the ECU. Reflash ECU.
Exhaust Valve Actuator
800 HO Only
(PWM Converter – Diagnostics) 520324 3 P1400 ON For all E-VES Diagnostic Trouble Codes (DTCs), see: E-VES Diagnostic Trouble Codes (DTCs)
5 P1401
13 P1402
12 P1403
7 P1404
2 P1405
800 HO Only
(PWM Converter – Position) 520335 3 P1406 ON
5 P1407
10 P1408
EV Actuator Overheat Condition
800 HO Only 520334 31 P1409 ON
EV Actuator Learning Default Position
800 HO Only 520337 31 P1410 ON
Exhaust Valve Position Out of Range (OPEN)
800 HO Only 520325 31 P140A ON
Exhaust Valve Position Out of Range (MID)
800 HO Only 520326 31 P140B ON
Exhaust Valve Position Out of Range (CLOSED)
800 HO Only 520327 31 P140C ON
EV Actuator / Gauge Relay 520328 5 P140D ON
3 P140E
