Tree Line Tactics
Cooksend
We all know the Pro is the bomb when it comes to technical trees. However if you had one mod you could do to improve it's ability to Rip the Un-Rippable what would it be (aside from improving riders skills)?
Yoda Feel the force flow within.:face-icon-small-ton
After I buggered up my stock arms, I went to 36" and it helps.
Practicing my skills in an open field helps to. Stick cones/markers in and practice.
I do thought love the smell of pine needles burning on my exhaust.
MO. Read the suspension guide in the owners manual and try it out (the adjustments).
Then ride and ride till you look like the guys in the vids. Then borrow someones mod and see if it makes it easier. Then ask how much it costs. Then make your own opinion and save up.
My thoughts are leaning towards the Alt. Impact 36" front end. I do like the idea of being able to run the sway bar. Nice to have the option anyways. The other I would have to say would probably be Kurts Gear Down Kit. Having a quick rippy sled in the tight trees is priceless (or maybe expensive). I really don't need a good set up or the trails as it is rarely more than a few miles until we dump off into the bush.
Any feelings between Z-Bros and Alt. Impact?
Put the skis stance in the narrow position, get the front and rear suspension set for your weight and then let it rip! Also spend some time pounding the sidehills and trees. Just try not and hit the trees :) Eric
This may be rider preference but for low cost big impact I would strongly recommend a low rise seat. I like Skinz but pick your flavor. Along with this a set of low rise bars will give that extra leverage in tricky situations.
add 25 hp to keep up with the piped m8000's.:israel::phone::face-icon-small-sho:brokenheart:
Cooksend;3702102 Any feelings between Z-Bros and Alt. Impact?[/QUOTE said:
From what I understand you have to grind the spindle to run the zbros arms. Only reason I'd go AI
3" camo extreme takes the tree riding ability to a whole new level on the pro chassis, that is the first mod i recommend to all of our customers followed by the zbroz 36" front end both of which allow you to retain warranty
