What did you use on the floor? It looks great. Got a new trailer coming. I am trying to figure out what to do with the walls and floor.
On walls wound up just using the 3/8" ply wood the previous owner had installed after they insulated. I primed them with a primer I use to block wood grain from coming threw at work all the time (2 coats) then drywall pole sanded it lightly to knock any raised grain down and then coated walls with exterior latex semi gloss paint 3 coats. Turned out incredible for 50 bucks and on floor I pressure washed then let dry and sanded with a 19" floor sander the stained it with a semi transparent 2 coats (1st brushed with 6" premium deck brush to get all the nooks and cranny a and the kick plate ) second coat with 12" roller. Color is black earth a dark dark gray and another 50 bucks. Had vinyl in my race trailer for motocross was fine but not a sled trailer thing plus this way I can touch up floor at end of season if want easily. But I have rollers for skis in trailer and no studs allowed with this owner also will be putting skis on carpet scrapes from the jobs so no rust spots under skis. Littlerly just 100 bucks made it 1000 times better and the 50 in new lights was worth it too. Sad part is the new tread plate cost as much as finishing the whole inside.lol since bought put 500 in to it and I could easily sell for 2g more than I paid for it
Before
