Getting ready to install. Going with ARC Audi amp and speakers. Contemplating a sub but not sure how much power it will use. Any feedback on how sub use affects battery usage?
Not to highjack this thread, but would be interested in seeing how (pictures) stereos are being mounted in trailers.
Want to mount one in my trailer, but would like to see what is being done first so that I can hopefully do it right the first time!
I am running a fairly large stereo in my Snowpro trailer. I have 4 Alpine 6x9 mounted in four corners of the trailer. I am running 110 watts to each 6x9. I also have 2-10" JL Audio subs in a ported box mounted right under my cabinets. I am running 1200 watts to the subs. I run a alpine head unit with bluetooth and mounted on the roof is 2 flip down TV's. Mounted 2 amps in the cabinets on the wall. The sound system is killer. Sounds so clear and real loud. The subs pound. I am trying to find some good pictures of my install. I am running 2 batteries and its been 2 years now with no problems. No need to spend the extra money on Marine grade audio. I don't even run that in my boat and never have problems.
finally made some progress on my install:
whipped this out on the laser:
used 3m spray adhesive and put scrap tiles of armaflex insulation from a job at work to line the nose for insulation and sound. put a layer of gorilla tape between all parts when mounting to reduce rattles and put several strips of 1/4" foam gasket on the back of the aluminum plate. has a pretty good sound - not hollow which i was worried about
mostly done, just need to trim the wood and get my 120v installed:
