Trailer Question?
Hi I cant find a trailer section. So i thought i would just ask the question here
If i have a 24 ft enclosed trailer with the wheel wells in side (not V Nose) Would i put a floor down or have it rhino lined?? or somthing else that would prevent the wood floor from rotting
thanks
Line-X, or any similar product would work well, except that carbides tend to be hard on that stuff anywhere that it makes a hard corner, and gives the ski something to catch on.
Just use marine grade plywood and seal it periodically. Line X is not durable enough to prevent carbides from digging in, not to mention adding weight and expense to the trailer.
Thanks for the replys. Is there a reason i would need a (v nose) verses a reg car hauler? The reason i ask is i have a enclosed trailer for the atvs and what not
all the toys but one. I just figured i would use the other snowmobile to pull it out. instead of buying another trailer.
Any suggestions on what to put on the walls?? Paint or somthing else
Cover the bed with something and then buy some ski boots that way the carbides don't damage the bed because just plastic is running on it... We use them on ours and they work fine and our bed is no longer getting dented/worn and such. It also protects the paint on the ramps...
