polaris has a team tip for the tracks on a stand...they say they are supposed to be noisy..they also say dont run the series 5 tracks on a stand...I will see if I can find the team tip for you....here is what it says....
2008 700 and 800 RMK 155 / 163 Track Vibration on Stand / Track Tension Settings
The involute/convolute driveshafts installed in these snowmobiles are designed for a track that has been “brokenin”.
When the track is new and run (dry) on a stand, it may exhibit a tendency to climb the center drive, causing
vibration. If this happens, lubricate the track and driveshaft interface by spraying it with water. This will stop any
tendency for the track to climb the driveshaft.
There should be no noticeable vibration with the involute/convolute driveshaft, even when new, when it is run
on snow.
Additionally, it is very important that customers adhere to the specified track tension requirements as outlined in
the Owner’s Manual. Proper track tension is critical for maximum efficiency and performance. Track tension
controls the approach angle of the track to the rail beam in powder conditions.
Track Tension Specifications (Reference appropriate Service Manual for adjustment procedure.)
Deep snow performance will be optimized when setting the track to the specified tension. Looser track tension
settings will cause the track to “bunch-up” in front of the rail beam tips, causing an improper track approach
angle and poor performance.
The first sign of a loose track on a snowmobile using the new involute/convolute driveshaft will be different than
the traditional racheting under acceleration heard with standard driveshaft - track setups. The rider will now hear
the racheting noise during hard braking, whenever the track is too loose and in need of tightening.
Remember the track tension must be checked and adjusted after the “break-in” period and checked periodically
to ensure maximum performance.
SUSPENSION MEASUREMENT
IQ 121
136 Coupled
136 Comfort
7/8″ - 1-1/8″
(2.2 - 2.9cm)
M-10 128 7/8″ - 1-1/8″
(2.2 - 2.9cm)
M-10 136 3/4″ - 1.0″
(1.9 - 2.5cm)
IQ RMK / Switchback 3/8″ - 1/2″
(1 - 1.3cm)
