Track speed
justinkredible56
09 Nytro 153" bone stock besides a hartman clutch kit. The kit is designed for a 280lb rider in gear, 162 track, 19t top gear, and aftermarket exhaust. I had the clutch kit installed but I haven't switched out the chaincase sprocket yet. I am taching at 9-9.1k rpm's now on flat land but and around 8.9 climbing but my track speed is around 30-35 mph's. I thought I heard you were supposed to be getting around 45 on the hill. What are my options. I realize that my clutching is off for what my current setup is (going to throw the other stuff on this summer) but if anything I would think my track speed would still be higher. Any thoughts?
Thanks, -Justin
Two things to keep in mind.
1) Spring Snow 2) Spring snow It is a lot harder to turn the track in the slushy spring snow than dry Utah powder. I think the gearing will help too. Right now is not the time to be tuning. Too many variables of change during a spring day of riding.
I appreciate the response, my track and new drop brackets got in today and the exhaust will be on in about a month. I kinda decided AFTER I posted the thread that I would just wait until all my mods where done to match my clutching. Again I appreciate the insight.
-Justin
I'm dead set on making this sled competitive without boost....too much hate on the 4-strokes out there. So nothing major for 4 years and the warranty is up.
What track do you have???????
With the weight and only 135 HP on a 162 track you can not realy expect much trackspeed , if it is a 16 wide with 2.5 paddles they are known to chocke the Nytro right down.
The sled is bone stock so it has the 15" wide 153 maverick on it right now. When I called tom hartman to have him build a custom clutch setup for me I told him to build it to accomadate mods that I would be doing during the summer i.e. 162 2.25" track and full exhaust system. So he sent me a full custom primary/secondary clutch setup and a 19t top gear vs. the 20 tooth stock gear. I have the clutch kit put on but haven't put the smaller top sprocket on. I've been riding both days every weekend for the past month and have somewhere around 400-450 miles now. I blew a belt my last ride out. Noticed that my primary and secondary were pretty hot. I'm going to call tom about it and see what he thinks within the week.
Something is not right , if you go to the 2010 clutch set up it works real well with just a bit of massaging for altitude.
If you start blowing belts something is wrong.
If in doubt go back to stock --- 19 top gear is a real good Idea especially with a bigger track. A friend has a series 4 track in a 159 that works awesome.
My Nytro mtx 153`with Powder claw track on it and 19t . 43-47 mph !
Spring snow or not.
ntm
with a TS suspension and a 162 power claw I was getting 42-47mph with stock clutching for 4-6k feet and a 19t in the chain case.
With nothing but a track and skid swap I made a believer out of a few people on the hill. Its not the pig everyone thinks it is.
Now I just need to figure out why the H@ll my sled isn't pulling that speed...any ideas? Just barely getting around to putting the 19t on top and the 162. I would think that it have the same results though because the lower top tooth is countered by the longer track...I'll check track tension and hifax before I try it again this fall.
-Justin
how can u complain at the moment when u dont even got all the parts on the machine. theem clutch kits are custom. but they only work proper when u have them put in completely.
I agree man but wouldn't you think that the clutch kit for a 162 pull a little harder than 35mph when the sled has a 153 on it at the moment? The sled wouldn't pull more than 32-35 bone stock with no adjustments made to the clutching...just tryin to get ideas on things to check while I'm not sacrificing riding for wrenching!
Thanks, -Justin
Sorry about bringing AC into this. I read the following from Kelsey and it makes sence no mater which brand you ride. Just something to think about. My M7 140 HP Climbing track speed is 48 mph last year.
The whole "Power to the ground" reference is very misleading... Clutch kits really do not put power to the ground.. You have X amount of Power at the crankshaft.. You transfer this power via belt, clutches, and gear-box to the track.. There are inherent power losses associated with this transfer due to mechanical losses of the components involved.. The components are still the components..meaning.. you are still using the same primary clutch, same belt, same Diamond Drive, and same secondary clutch.. So, the components do not change.. What changes is how effectively and efficiently you use these components.. If all the power transfer losses via these components were "ideal" you would have 100% power transfer.. But they are not and there are losses..
So, where does that leave you??
Let's break down the losses in VERY SIMPLISTIC terms...
1) Primary clutch.. Works great and will get the job done in terms of squeezing the belt.
2)Secondary Clutch, also works fine..Shift gets stalled due to the massive spring they use...also has a large tendency to lose belt grip. Which brings us to the the main culprit in the loss dept. BELT!
3)BELT.. This is the real player.. If your belt is slipping, you created more heat and less "grab" on the clutch sheaves and this will lessen track speed.
The key is to have the belt grabbing well AND to have the shift ratio in the MAXIMUM ratio available for ANY given instance (hill climbing, racing etc.) THIS is what is really determining how fast you are spinning the track!
So, all this HP tothe track thing is really not about track HP but more about track speed! and belt heat.. So HP is really not the right term IMO..
The key to having higher track speed is to be in a higher "gear" via your clutches.. ANYTIME you are spinning the track faster, you are in a higher or lower depending on how you look at it) shift ratio from the primary clutch to the secondary clutch. You can NOT increase track speed and still be in the same shift ratio via clutching components changes alone.. 50MPH is 50MPH regardless of what is in either of your clutches. The belt is fixed length and the shift ratio will be the same regardless of what spring, helix, weight etc, you have installed.
So, the real task is to make your track do 60mph when the others are doin 50mph.. to accomplish this you MUST be in a higher shift ratio.
So, no matter if you have 140HP or 200HP if your clutches stall the shift at 50MPH you are only going to do 50MPH no matter how much HP your engine has..
This is where the DD kit , we offer, comes into play.. We find the stock secondary to stall the shifting. This will not allow you to reach the speeds you desire..
With our kit, we change the way the secondary handles the load and make it NOT STALL the shift.. So, this will ALWAYS translate to higher track speeds .
Belt heat is the other "player" You MUST keep the belt slip to a minimum.. With a slipping belt you cannot achieve optimum speeds.. So, the clutch components will be a big player on how much belt slip you experience.
I need to sit down and write this in more specific terms and will dothat soon.. But, for now, I hope this made some sense..
Kelsey
Update: after putting the 19t sprocket and the 162 on I'm getting 41-42 mph track speed. I'm happy with it at this point but will get some more tuning done this weekend. As for why I was only getting 32-33mph track speed before I am thinking that the track was to tight from the factory and that the belt I was using was toast. I will continue to update this with more info as I get her dialed in!
Good to hear! Are you running you Attack 20 forward or reverse? Great track in the powder sucks otherwise. Unless you turn it around and straighten the lugs...then its pretty sweet.
Running the attack 20 in hillclimb position, from what I hear that's the only way to get a decent track out of them. You have to run it in hillclimb ONLY from day 1.
From my experience if you don't straighten the lugs it will trench like a mother. Once I straightened mine, it was a great track. Gnarly roost. Plan on bringing up the rear on the trail.
Where you riding at already?
I haven't been able to get a good solid ride in yet just headed up to Tony's grove for some crappy trail riding to make sure everything was working and get my rpm's back in check. There is only one hill you can make it to that has a decent amount of snow to tune for hillclimbing but getting to it is quite an adventure. A bunch of buddies and I are headed to Afton Wyoming this weekend. Word has it that guys are riding in 3.5 feet of snow! I guess we will see!
