I started this thread and the first thread,
http://www.snowestonline.com/forum/showthread.php?t=251409
because I was testing the new MDS turbo weights. I was running a full on twisted kit, clutching and all. I put the stock secondary off my m1000 on it with one plastic shim and a shift assist and the mds weights with a polaris black spring. I ran it and got some numbers and on the same day same hill installed the weights.
Twisted
9600ft
6lbs
8000rpm but jumping all over
TS-42-43mph - in 2' fresh up hill at very low ground speeds.
you could touch the clutches but not for to long
MDS
9600ft
6lbs
8000rpm and held with 50rpm even crossing tracks.
TS- 51-52mph tested 10' to the side of the other runs
after 3-4 hard pulls you could leave your hand on the clutches, clutch temps where: pri, 97* sec, 94* belt 104*
power comes on very smooth
with twisted secondary track speeds where 46-47mph. clutches a little warmer but not much.
Sense then I have had some heat in the clutching but I think some is due to the low end, I am running a KMOD suspension and have to run it very tight to keep it from ratcheting. With the setup it engages very smooth and you can make it crawl without spinning if you want, but with the tight track and low engagement I think its causing a little slippage and is a little lazy for just a second.
On hard wide open pulls the clutching stays cool and my belt looks great through all of it.
I think I can correct this problem just havent done it yet because I am having a blast with the combo of TWISTED - MDS - KMOD, I am pulling of stuff people shake there heads at.
I am also planning on trying a few things to make the upshift even faster. But for right now the sled is getting Kmod rails and a 162 PC, can't wait to see what it does now.
At 10bls it really kicks A$$
Twisted
9600ft
6lbs
MDS
9600ft
6lbs
