Track rubbing on drop bracket
B
BYOB
Got a dilemma here. My track is rubbing on the right side drop bracket. I have 5 rides on the sled and noticed when I went to tighten the track a bit as it has worn in now.
When I get the track centered on the rails with the tensioners which happens when they are almost exactly the same depth, the track rubs on the bracket. I have to tighten the right tensioner almost a 1/4" to get the track centered between the drop brackets but then it is way off to the left side of the rails and obviously uneven.
Skid is all stock as it came from the dealer and everything appears straight(tunnel, rails, etc), any ideas?
the best solution is to grind down the edges of your drop brackets. even if everything is perfectly centered the track will still move side to side as you ride. both side of my track were getting torn up. it stopped as soon as i took a grinder to the edge of the drop brackets. you can probably see black marks from where the track is rubbing? just grind the edge so it is smooth transition and shouldn't have a problem.
pv
