The 2010 XP 800 Summit X in my shop right now has the stock drivers /track.
With the XP having front bulkhead heat exchangers and full length U-coolers in the roof of the tunnel... I'm not at all worried about ice build up there from "too much" clearance.
It has 1" front clearance and 5/8" at the top...with the stock 2.33" lug.
The top is the tight clearance spot.
The 7 tooth, 3" pitch drivers increase clearance by .30" (about 5/16")
A 3" track lug on the 7 tooth drivers will take the clearance down to 5/8" front, and 1/4" on the top.
A 3" wont rub on the top unless you run the track loose.
Running the 3" track at anything less than factory tension will, IMO, lead to early track failure and delam from from the excess heat buildup.... not to mention diminished performance from more friction across the hyfax and the paddles "laying down" because, without proper tension, the leverage of these tall paddles will flex the track belting and lay down because there is not enough tension to keep them standing up
"Not Rubbing" and giving proper performance are not necessarily the same thing.
The XP has pretty good clearance for a modern mountain sled.
Drag from lack of clearance is more of an issue in heavy/wet snow than light/dry snow.
A 3" paddle will move more snow thru the tunnel than a 2.5" paddle. More snow, less clearance... more drag.
Here is my take on the topic from another thread in the Poo section... but it applies here IMO.
Good info .Damn Thought I had my decision made
