I have an '07 Apex with a Boondocker turbo that I have yet to get on the snow (but that will change soon). However, in getting it ready to go, we changed the box from a boondocker to an attitude box and I checked the TPS settings through the dash diagnostics.
I have read that it is supposed to read 16 at idle and 96 at wide open. If I set it at 16 for the idle, then the highest I can possibly get with it wide open is about 85 (and that's manually stretching the cable as tight as it will go.
If I set the wide open setting at 96, then the idle setting is about 31 with the cable having slack.
Is this a bad TPS sensor or is it probably something else wrong? Help!
