I would like to know the torque spec for the bolt that holds primary clutch on, from a 2007 Summit 800.
2007 Ski-Doo service manual states 66ft/lb, run and brake 5 times, 70 ft/lbWhat manual are your specs from skippyh2o?
the service manual for the 08s says to torque to 89 lbft. excelerate at low speed not to exceed 20mph and hit the brake 5 times and torque to 89lbft again.
The torque on the 800R is higher then the older sleds because it is a taperd shaft instead of a splined shaft.
The torque on the xp is higher then the older sleds because it is a taperd shaft instead of a splined shaft.
2008 BRP manual
Hmmm ... I must've got the "factory option" taper on my '07 then
Sorry, I meant to type 800R
CHEERS
07 800r is the same as 08 and 09 800r.
The 05's have taper on the end of the crank, but isn't the shaft between the two sheaves splined?
I don't know alot about the older rev's. 08 xp is my first doo.
