rmk2112 Well-known member Premium Member Oct 25, 2010 #1 Hey guys, need a bit of info here. What are the ft/lbs torque setting for: Lower chain case gear bolt Upper chain case gear nut Secondary (driven) clutch bolt Thx
rmkboxer Well-known member Lifetime Membership Oct 25, 2010 #2 not sure what the torque is but make sure you use loctite on the lower bolt
POLZIN Well-known member Premium Member Oct 25, 2010 #3 i only remember the secondary off the top of my head its 23ft lbs. the rest I will look up when i get to the house !
J jmitchell Member Oct 25, 2010 #4 case bolts 8mm 25ft lbs 10mm 28ft lbs cylinder bolts 40 ft lbs head bolts 27 ft lbs
H High Velocity Well-known member Oct 26, 2010 #7 Upper sprocket - 50 ft/lbs Lower sprocket - 19-21 ft/lbs
POLZIN Well-known member Premium Member Oct 26, 2010 #8 oops! forgot to look that up last night ! looks like you got the #s you needed anyway!
