So this is a math question. Is IT possible that at 4000 rpm when the sled starts rotating the driveshaft, there is roughly 1000 ft lbs / 1600 nm? As im playing with the idea of electric direct drive this number will crush that idea.
It's much less than that. The torque load obviously can't go beyond what the engine/driveline is capable of producing. So, look up torque curves of your snowmobile engine. Then multiply the clutch. I believe a typical sled clutch is about 3:1. My guess is an 800 probably produces about 50ft-lbs at 4000rpm, which would give you roughly an ideal max torque at the track of 150ft-lb.
yeah that makes way more sense. But should not the clutch ratio and the gear ratio and the final driver be in the equation too?
