Just got done checking my 11 pro over and I decided to do a compression check. At 1600 miles It is at 70-75 PSI, can anyone tell me what spec is? I'm guessing since I want to put high compression heads (Bikeman) on I should probably do a top end rebuild but I just wanted some opinions. Anyone got a spec sheet they could send me on clearances and torque specs on stock pistons? Or if I buy aftermarket pistons will they come with specs? What are your recomendations for pistons with heads?
Also I'm getting what I consider to be a little excessive leakage on the chaincase seal around the crank, anyone else have that issue?
