too much engine movement?
You can pretty much tell the condition of the pro's mounts by looking at them, the flat spots are very noticeable if worn out.
In a pinch, you can rotate them 180 degrees to get a few more miles, or a limp-out.:face-icon-small-win
Just grab the drive clutch and move it up and down and front to back, you know if there bad, i replaced all 4 of mine (2 bad ones) on a 12 at 1800 miles, all 4 are cheaper than one belt!
My 13 has 700 mi on it the rubber mounts are squished to one side with a gap on the other side. Is this normal? They are pushing down and back.
Sent from my DROID RAZR using Tapatalk
From what I've read and my own sled; yeah, pretty normal. Had 850 miles on mine and all 4 had some slop. Got 4 new ones and even brand spanking new I wish for something tighter..
If there is an option I doubt I'll ever buy stock mounts again.
RS
I was thinking of trying one or two of the "solider" mounts on the PTO side (either the front only or both).
I have a torque mount but still only get about 7 to 8 hundred miles out of those two. The front PTO goes first.
Anybody try that?
Here are some pics from my 2011 w/ ~3k miles.
The MAG side looked the worse. Rear PTO looked really good, Front PTO wasn't too bad.
MAG side was definitely shot.
I ordered "2204633 - Kit, Bolt, MY 12 Engine Mount [Incl. 12,19,21]" from Parts Pit Stop, $65.69 + s/h.
Actually heading out to install now. Hope this cures some belt wear issues....will also be re-shimming the 2ndary as needed afterwards.
