ethanol
I recently read an article on marine 2 stroke engines; they tested various 2 stroke engines on e15. Some engines did not even finish the test do to melt down. I know we only have e10 here in co, but if you use an alcohol based boost witch most are you will be around e12 or so. Now to the point ethanol does make a difference on 2 stroke motors if you don’t take some precautions like don’t use alcohol based boost do use something like startron to keep water separation down. You should not have any problems. As far as octain goes both my sleds are ported and moded I do see a difference even above 10k feet if I use boost on 91.
