I am having an issue with the stock fuel pump. I unhooked the power from the secondary Walbro Fuel pump, and the sled would start. However, fuel pressure would spike to 38-40, which is normal, but after about 5 sec, fuel pressure drops to 30 PSI.
My question is...WHY? Could it be a bad Fuel pump? Could it be an electrical issue?
The higher in elevation I go, the less fuel pressure. I can't imagine it being a electrical issue, because the electrical system should be at a constant, not up and down.
What could it be? Bad stock fuel pump?
