New to the turbo. ovs race gas kit, Previous owner installed high flow fuel pump. It hasn't run in a while, so I've been methodically going through it. Fired it up today after many priming pulls. Fired up and wanted to run right out the side of the barn, if it had a belt it prolly would have. Settled to a manageable 2000 rpm, looked down at the regulator gauge and saw 60psi!! Needless to say I adjusted it down a bit, pulled it over, did the same thing. Got it down to 40 after a few rounds of adjustment and still surging. I'm not sure where to go from here. Wondering if the throttle surge and fuel pressure are related. I suspect they are. Need confirmation though, throttle linkage is where it should be.
Appreciate any help you can lend, Tim
