tips of rails hitting driver teeth
i have an 03 mxz x. sc-10 skid and 1 3/4 in. track.
when i try to spin the track by hand the rail tips are hitting the sprocket teeth and not allowing the track to sping. only thing i have noticed is this sled has 2 drivers, not 4 like i saw in the 03 mxz parts book.
front shock is out of skid now too, don't think thats the issue though.
Sounds like you have extroverts on your front drive shaft and your clipping your front tips on the rails. Do yourself a favor order some anti-stabs from Wahl Bros and remove plastic tip from front of rails and cut back aluminum stub. No more worries !! I do it to all my sleds plus remove all extra boogies and run hyper-fax slides plus ice scratchers. Thats the ticket, good luck
I had the same problem on my 2003 MXZX 800 when I put the extrovert drivers on it. I ended up just drilling holes an inch back and moving the suspension back. Not sure if that was the easiest way but it solved the problem and allowed more track adjustment for the 136x1 3/4 track I put on it
