P
polarisboyc
I wondered the same thing. There is very little difference.
I also heard the 12's had different cranks in them?
Just make sure what sled you buy it comes with a good warranty you will need it. 1495 miles 11 assault cracked cylinder,rings shot,1200 miles 12 assault broken skirt = new short block 12 163 clutch broke in half they ended up putting a short block in it. 3 sleds different owners same town not one of them has made 2000 miles.
We are getting ready to tear down another 12 163 with a turbo to install the fix kit and we will check his cylinders.
So when someone tells you how good they are ask how many miles it has been ridden in the mnts. To me if you don't have over 2500 miles on it you really should not voice your opinion on how good they really are.
Since 08? Polaris has NEVER built an 800 that lasted. Since the 2000 RMK the 800 has had MAJOR problems! I find it absolutely ridiculous that they will be going on 12 years (they didn't build an 800 in 06 and 07) of a POS motor and still haven't figured it out. If they didn't have the Pro, I bet they wouldn't be producing snowmobiles any more. Yes the Pro is a fun sled, I just wish Polaris would put a motor in it that complimented the chassis. I bought a 13 just to have the warranty for WHEN the motor goes down. But I'll still get un-easy going in a place where if it goes I can't get it out. You'd think that by paying $12,000+ for a TOY it would last more than 1500 miles. Rant over..Look at all the ads to fix the 800 problems longer rods , different pistons ,the gismo, custom pistons and spacers . There is a problem since 08 ask yourself this what happened to the 700 it worked.
bone stock they work pretty good, as said turn the oiler up to burn 1 qt per 10 gal of gas, and add 1 pint to every 10 gal of gas..clutching..slp blue/pink spring with a heel heavy weight(I run slp mtx weights) helps..a helix can but watch for excess clutch heat, for deep snow try to keep the skid springs as soft as you can(especially the frt track shock), avoid carring stuff on the tunnel if you jump or bottom the suspension all the time...other wise..ride it(try it stock first...the sled is damn good as it is delievered ) if you ride extremely hard..might want to brace up the tunnel..(they can kink the tunnel in the rear and up frt between the frt skid bolts and the chaincase(I do make brace kits as do others ....)
Frisco..heres my opinion on oil and the poo motor..in the dragons , poo poured the oil to them, most used at least a qt and a 1/4 per tank of fuel as delievered..many used much more...these motors ate topends like candy..yet it was rare that you ever heard of one having a bottom end issue..rareer still that they lost a bottom end bearing...now..on the pro the only oil the bottom end gets is from the oiler.., the top end..well it doesnt get any..except what can get pulled up from the lower end....little to no oil put in the fuel is ever going to see the bearings in the bottom end..(just wont because of how the injectors spray the fuel up into the topend)..so I turn up the oiler to feed the bottom end, and then feed the top thru the fuel..just as polaris requires the dealer to do everytime the motor gets touched..from brand new out of the shipping crate to every time a motor gets pulled down..now do you think burning a qt and a 1/2 of oil for every tank is going to hurt it? or hurt performance? it wont..its simply a way to help make sure this motor lives...and oil is cheap compared to a motor....Really 1 qt per 10 gal. and a pint mixed????? I would say thats excessive. mine ran great with a turbo last year at 54 to 1.
Next year I will be running more oil but not 22 to 1
I run a little oil from time to time in the tank. I'm also religious about warming the sled up in the parking lot and holding off on full throttle pulls until a few miles of riding. Blurp the throttle all day.
I never lost a CFI4 motor and had over 2400 miles on it. A group of us (9) have Pro's/Assault's and nobody has lost a motor in our area yet. I think the elevation helps a little here. I'm not saying it doesn't happen to people but I certainly don't consider the CFI2 a failure. I find it funny that people complain about the motor and still buy the sled!
