Tipped up or straight rails
mrsnow
Let's hear it, pros & cons of tipped up or straight rails. I personally think that tipped up has more advantages than straight, but let's hear some more.:argue:
Rails
I totaled my 2012 Pro 163 last year which had straight rails. Bought a 2011 Pro 163 which has tipped rails. Was only off the snow for a week so I had a pretty good “Back to Back” compairsum.
I like the tipped rails a little better! Seems to lift the skies easier without the need to tighten the “rear skid” front shock or soften the rear shock. It doesn’t lift the skies wildly. I personally like a little ski lift some don’t! Haven’t noticed any downfall to the tipped rails. A bonus of the tipped rails is on trails it doesn’t push through the corners as bad. If that matters to you?
Personally, So far I prefer them to the straight rails. Not a lot of difference though!
Have ridden both as well. Not a big difference. Tipped lift the front end easier for obstacles and generally make for a little less skis pressure. Straight are advantageous on really steep climbs, or if you make a good bit more power than stock. I imagine the straight would be slightly stronger as well? Not sure.
If you think about the angle of the skid most of the time ie. powder or climbing it would be high in the front low in back i think tipped up would keep more track on the snow, plus the fore mentioned advantages IMO.
