timing key at 10k ele
M
minet
anyone running a timing key advance on thier m1000's?
going over dynotech chats and it shows some benifit at sealevel ,, any cons to doing this up in the mountains?
thanks
they had it on a f1000,
hooked up to dyno ( equivalent of intake / pod set up )
vf 8 petal reeds and 2 ^ timing key
chart was 6900-7600 witch was pretty flat anyhow,
reeds and stock were almost the same until 7300 , then reeds were clearly over stock, but not greater than peak hp between 7000 and 7300 of the stock..
stock showed 172 at 7200 ( airbox removed as explained )
reeds,2key showed 176 at 7100.
on 93oct
so could i expect these results at altitude?
ya, i was told that a key would not be a good idea , so scrapping the plans on that
