guys i have an issue i would like to try to resolve if possible. i have noticed the front end of the rear skid has a "sagging" issue. even with higher air pressures (over 100psi) in the front arm shock. to give you some background, i am running an 08 mtx, i weigh 200 with no gear on. i am running the stock front shocks with stiffer springs, (i have the new fox evol X shocks from the shorty se version of the nytro, on the way). i have the timbersled front end. i am running the stock yamaha rails cut to timbersled specs, mounts are in timbersled speced spots at this time (front and rear mounts). i am running the stock yamaha mountain ski and carbides on the sled.
i have the twitchy front end issue that i just cant seem to find a middle ground on. i"ll be the first to admit, i am not a big rider forward fan. when watching other skids just sitting on the sled doesnt loosen the limter straps. when i just sit on my sled, the front arm drops so significantly the straps loosen right up. even pulling the straps to their tightest setting doesn not eliminate the "sag".
i believe this to be one of two probelms, and i am looking for clarification to fix this. i believe it is either A: too soft of a valve stack and the air pressure adjutment cannot overcome the weight of the sled and rider combo.
or B: the geometry of the skid in the stock front holes is contributing to the shock being too soft for the application and collapses the front arm too soon.
the problem i am trying to avoid is not the viewing of the loose limiter straps, it is getting rid of most of the ski pressure on the sled because, the front arm is so low... the front ski shocks hold all the weight of the sled v.s being balanced with the rear skid.
i think this will aid with the twitchiness associated with the nytro front ends, and the heavy feeling steering.
does anyone (including the ts guys that frequent the site) have any suggestions? the front arm shock revavle seems the easiest but, with the high air pressures i have tried... not getting rid of this phenomenon, i have a hard time believing that is all it is. i am almost wondering if the shock is too short for the application, or the stock front mount is the wrong location for this skid set up.
the front arm relocation will be the hardest thing to do, as i have no dimensions on how to relieve the front end of the rear skid in the mount area.
does anyone have any ideas how to help this situation? thanks in advance. ski
