interesting to see the different experiences with bearings on the bikes. While building 4 bikes this last few years I have tried to make chain sprocket and bearing alignment perfect...............which is impossible and frustrating. Welded frames, flexing aluminum, imperfect motorcycle frames, all around big compromise. MH is doing a great job.
Sled mfg companies with 40 years of experience are still turning out duds on occasion as far as bearing failure is concerned. All side load issues on the sleds.
I think the key here is observe, watch your bearings, know the signs that side pressure, chain misalignment, vibration, tight chains can cause. Tight drive chains in packy snow is one killer. Rough landings and motocross bumps got to kill the drive shaft bearings. Leaking grease out of a bearing, often just a little trace of black around the inner race.......oops, not normal, chit happening, beware.
