M
modsledr
2012 Pro...Installed Fastrax Throttle Block, and Tether, and did the Fastrax Throttle Safety Switch Bypass. Now we do not have reverse.
Tried the modified switch on another Pro, and it works perfect. Installed the ECU on the other Pro, and it works perfect.
Disconnected the hand warmers, thumb warmer, brake light, etc...to see if there was a short interfering with the system...no luck, still no reverse.
Unplug the modified TSS and sled goes into "Limp Mode" as it should.
Had the sled at the dealer checking the TPS, and they confirmed the ECU was getting the reverse signal when the button is pushed.
Running out of ideas...thoughts anybody?
