My throttle response isent what it used to be, what can I check on my sled? What causes throttle response to get worse?
i just installed my kit, had about a mile on it and hit the rev limiter and boom a big backfire. I have the tdr reeds which still look perfect but the reed cages were the problem. Where the two cages meet with each other there was about a 1/8" gap. both cylinders looked this way, Needless to say these cages are whimpy.
Any engine codes?
There are a few different things that could be triggering that code. But it is obviously what is causing your less than crisp bottom end. When you start your sled the raves should get sucked in to fully closed. If they don't it's going to be like you've lost running compression. Pull your black cover off of the raves and check to see that they close when you start your sled. If not you have to check for leaks in your vacuum system that power the raves. Check your valves over closely for any oily mess too, they could be cut or loose. If you can eliminate that possibility, then you need to determine if your solenoid that controls the vacuum and the valve mounted between the reeds are both working properly. When the valves don't close at idle it will act exactly like bad reeds. Tough starting, rough idle, sloppy bottom end. Start the sled once you have your rave cover off and listen to how rough it idles, then press the raves down by hand to the closed position where they are supposed to be and listen to the idle. It makes a HUGE difference. Good luck!
Yep, check all the vacuum lines going back from your valves. They are the black lines that go back to your solenoid and tie into the clear lines with "springs" in them. From there they go to a white valve sitting between your reeds on the case and from there into the crankcase where it picks up the vacuum. Even a pinhole will do it. Check very closely or if you have a vacuum pump/gauge you can check to see if it is air tight.
Perform the exhaust valve calibration using BUDS or CanDooPro using a vacuum/ pressure gauge if the valves are in question. Also use BUDS to calibrate TPS and throttle opening %. Once you know all these are correct, it narrows down the possibilities.
Maybe throw in new plugs, they can go bad and do often on turbos, especially if you run leaded fuel. It seemed like plugs lasted 2-300 miles on a buddies turbo etec last year. New plugs and all was well.
That is the other thing my dealer did is out new plugs in it, something about let years plugs were working better then this years?? They must be different a little.
