Does anyone know what the throttle pin switch does or changes in the ECM on these machines? The new machines only have one switch where in the past there were two that worked together to detect the throttle if it froze open. It woluld then kill the ignition.
On the Pro with the single switch when the throttle is at idle position (switch closed) there is a reading of 2300 ohms. When the pin switch is depressed the switch opens for a split second and then goes to a very high resistance reading in the K ohm area. If the switch is taken out of the system completely the engine light will come on on. This will be an open, which the light does not flash when the switch goes through this open when the throttle is activated. If you connect the two wires going into the harness the engine light will also come on (to low resistance apparently).
Just wondering what the switch does and what changes the resistance values do to the runability of the systems it affects?
I am installing an aftermarket throttle block and would like to know what to do with the switch or if there is a certain resistor I should be installing on the wires since the switch is no longer in the system.
Any input would be appreciated. Thanks
