This Is A Must See!! Unreal Technology..
Ideally with an over penetration of renewable energy (more supply than demand), electrolysis would be a perfect variable load tool to match times when there is too much wind and not enough load. Instead of curtailing the power output of the wind farms, crank up the load from the electrolysis systems and produce hydrogen.
Basically, you are describing energy storage. Using hydrogen for this purpose has several drawbacks. Namely the efficiency of the system and the storage problems that you have with hydrogen.
Under the ideal circumstance, you would use renewble energy 100% of the time and reduce the coal/nuclear sources when energy demands are low, not the other way around. If you want to see a interesting excercise in energy storage and the economics of the electrical grid, take a look at the following link:
http://www.deseretnews.com/article/1,5143,695272137,00.html
Hey IDcat, refer to my response, the fifth response in this thread. It's a Brown's gas generator. They can't even tell you the correct combination of the output gases. It's not HHO it's H+HO, Hydrogen Hydroxide. Sorry dude, buy you'd probably do better with an aluminum foil pyramid over your engine.
Yha HeadLever, you got the idea. Hydrogen is just like that pumped water generation storage system. Funny how the environmentalist found nothing but problems with a green solution to a problem.
Over the years you occasionally keep hearing about people & their "invention" or method to save fuel or even eliminate the need for it.
Some may have been credible, some not.
But my point is....What happens to these people?
Do they mysteriously end up dirt napping?:confused:
hehehe... "cow magnets"... :D
that looks like a supository for robots ....
