summitag163
New member
Pretty sure it is the moisture in the air causing the icing, not snowdust getting in, will need to heat the carb bell a bit.
Here is where I'm at now riding 6-8000 feet with a 38 PWK on a basically stock motor.
170 main
48 pilot
float 16 mm
DGM needle 3rd clip
This time of year a tunnel cooler won't help you the problem is keeping heat in the bike. If you at not making engine heat no carb heater system will help. To keep ice away I like to see 130 plus coolant temp coming out of the head, In order to get rid of your icing you need to retain more heat. It may be that you are jetted too fat or you may need to shroud the motor or both.
You don't happen to have one of those pump primers on the carb by chance do you because they leak like crazy which would explain the premix in your ice.
M5
I’m riding 3000-6000 same carb. Would you just richen up both jets ? Or. Hangs the needle too ?
I ran race fuel ported set up with a forged piston snow only... 250 hours... Changed the rings ever 50... At 250 the piston was starting to look stressed..... Even in that time lost a radiator and all the fluid... Still was good with rings. God I miss that bike[emoji16]500 guys, how many hours are you getting out of a top end, just curious.
M5
