third set of injectors
K
kcdavidak
just a thought, if you can throw enough fuel into the engine to wash out det how much boost could you make with pump,using 2860 or 2876. adding third set wouldnt be to hard to do piggyback off secondary .so stock inj,2nd inj in intercooler bd, third in throttlebodies. would it work?
No, you can only run so much boost before you need higher octane. Or make so much power before it needs more. Some are already using a 2876 with secondary injectors and on some kits you can max out the octane requirements with the stock injectors.
ok so use race gas stagger injector timing,first set 6-7 lbs 2nd set8-13, 3rd 14-20, just thinking what if ,more fuel more power.
Do some more research you can run big boost on 2 sets. To get more boost on pg you have to alter the timing and compression.
