Hey TurboAl, Clint here from Calgary... I was at your shop last year, and you mentioned that you can drop in a thermostat right in the head of my 07 REV? If so, which thermostat would I order? Would it be from an 06, seeing the 08's have the inline external thermostat?
I am trying to avoid the crank bearings from seizing, as this is a known problem for the 07's. I am planning on installing a water temp gauge, and thought the thermostat would be a good idea...
Hey Al, I was under the impression that you had to do work to the head to drop a 06 t stat into the 07 head....or have I been mis-informed? I will be putting a t stat on this year and it would be great to know if I can just drop in one from an 06.ck1 the t stat we use in the 07 is the 06 one from doo, throw a temp guage in when doing it, good idea on the 1000 as mentioned above
Thanks I am looking into this for a 07 800R. Why would AL have a differant opinion?Does someone have a clear answer?
I purchased a '07 800R this spring & was planning to install a PSI inline thermostat (w/built-in bypass to allow some coolant flow) inline between the reservoir & engine inlet.
