M machinehead Free Member Jan 6, 2016 #1 Can someone recommend the location for a thermobob , on an older red TE511 ? Referenced to the drawing, # 7 comes off the head, and the short part of #8 attaches to waterpump. Bike does not get close to temp., and over fuels, which results in a oil/gas mixture change every full day ride. Thanks.
R Rush44 Well-known member Jan 6, 2016 #2 Stat would go into part 7 and then the bypass return would mount into part 8 on the return from rad hose. That 2nd picture down in the 2nd image you posted you can see exactly where it should go. Check with Bill at Watt-Man and he might give you more info.
