The Mod Runs!!!!
got it out of the basement today, wife says it can't come back in!!!!
attachment.php
snowies maybe in 2 weeks,
yep only helmet i will wear.
zx lightweight hillclimb chassis 156 with a 900 ultra motor. needs more transfer in the back!!!! it has a set back on it and i don't weigh enough to make it transfer. need to wheelie!!!!
If it wheelied in that frozen ground, low snow condition, you probably would have too much transfer. You have to be just spinning the track in that stuff !
i have a walk out basement with french doors (just for my wheeler and sleds) but now i have a shop so she says no more basemnet.
your right on the low snow and ground. but i had no lift at all!!!!
long live the NMFH
Drop your front arm mount down a little bit, a little loss of AOA won't hurt you on that sled.
It will to an extent, when you grab a handfull, the rear of the skid collapses and the front extends to the limiter strap, you CAN loosen the limiter strap but the length of the shock will limit it as well, by dropping the pivot, it allows the front of the skid to fall out farther, thus, giving you more weight transfer.
If you built a climber, why the hell would you want more ski lift. When you put it in a few of snow, if you have any kind of power coming out of that motor you will have plenty of ski lift. Wheelies look cool but hinder real climbing ability, but if your into looking cool then lower the front torque arm and have ablast.
P.S. NMFH
im a cat walker!!!!! that how i have done it sence i got this motor some years ago!!! i don't do all that much climbing with this sled, hope to this year but well see.
if you park your sled in your new building, be sure to tie it to the floor; you can use the same d-rings that airplanes use:p Yes, I have seen your pictures of your building blown over three acres; I was putting up trusses on the same day up here!
