So I finally installed a tether. I have not used one in years. After reading some of the stories on these forums you've done your job to convince me.
I choose the Pro Designs Tether in black because of the clip style Key and many feel they are more reliable. http://www.gobigparts.com/Pro-Designs-Handlebar-Mount-Tether-Switch.html
Installation couldn't have been easier. No holes to drill, no brackets to be made, and no wires to be cut and spliced. My sled I installed it on is a 2012 ProRMK 155.
So the first thing i did was to find a spot on my handlebars where I wanted to mount it and felt it was out of the way but still easy to plug into. Mounting it just takes a 9/64th allen wrench.
Once that was done I removed the hood to make it easier to access the wiring harness near the steering post and dash. Once the hood is removed you will see a black nylon cover with velcro around the harness. Inside you will see 2 open connectors. One is black and with the plug side being more square and the other one is white and is smaller with more of a rectangular shape. The black one is the one you will need.
Then I took 2 small male connectors and crimped one on each of the 2 wires that come out of the tether.
Then you just plug them into the terminals in the black connector on your wiring harness. Doesn't matter which wire goes to which side of the connector.
When done zip ties your wires up neatly and tuck the connectors back inside the nylon velcro cover.
Fire you sled up and test the tether to make sure when you removed the key/cord that the sled shuts off.
If you want to do this to yours and you order the tether from Go Big Parts I will throw the 2 connectors in for FREE.
I will also crimp them on for you if you want. So when you got to my website link you will see a Model option where you can select ProRMK with connectors and ProRMK with connectors installed.
So if you want the connectors but don't want them crimped on the end of the wires select the RMK with connectors.
If you want the connectors already crimped on the end of the wires select RMK with connectors installed.
Dont forget to select Super Saver USPS Shipping to save a little more. Shouldn't add any time in this case.
