Rapid Bike Racing / My Tuning bike
Got some more info for you guys about RBR.
A real breakthrough in technology applied in the motorcycle sector, Rapid Bike Racing is the most complete and innovative system available today to manage the engine EFI/Ignition working through add-on module. Features supported are Injection map management, Injection range +150% -100%, Ignition map range +10 -10, map configuration management, RPM limiter, Enrichment in acceleration, My Tuning Bike management, Switch maps management that can be switched on the fly, Racing module analyses and manages up to 8 input channels contemporary thanks to a calculating capacity ten times higher then what already offered by the esteemed Rapid Bike 3.
CAN-BUS autotuning option for RapidBike EVO/RACING
My Tuning Bike is the new optional application working through CAN-BUS communication and a linear oxygen sensor (wide band) to perform self remapping of the injection and to be automatically tuned to a target air/fuel ratio.
Powder Lites has a custom made wire harness that will adapt your RB3 harness to upgrade to EVO/RBR module plus add My Tuning Bike with wideband auto tuning which can be setup for optimum air/fuel ratio that you need on your application.
My Tuning Bike will auto tune your map and you can also send calibration to RBR for changes in original map.
RBR comes with USB cable so you just connect to
www.rapidbike.com and, after a quick registration form, you can download RapidBike Master software for free to calibrate your new RapidBike module.
www.powderlites.com
250-836-4422
