P
Strong running Powderlites - Nice
Notice when the Nytro is idling at the end that it has the same rattling sound as mine - what is that ? mine sounds the same and seams to be right around the turbo - bothers me so any idea ?
$799. for box and harness. Racing ECU
My Tuning Bike will be about $350.
Kyle Micku was running one for the last few rides on his SkiDoo Turbo as well.
Old RB3 harness can only run Professional Tuning bike to build maps.
My Tuning Bike is Autotrim with wideband up to 15% and doesn't change maps. Fail safe always goes back to Racing map .
RB3 guys we are working on adaptor harness to upgrade to new box.
Will let you guys know when we get them.
Edit: Shows what I know, bought sled with turbo on it, is there a electric oil pump that is quiet ?
Ok, so lets see if I am understanding this.
So you get a map that is pretty good and on those days when the map isn't quite right the my tuning bike will make a correction to the fuel up to 15% plus or minus, based on what the af ratio is? Will this be enough to make up for the regulator being off a little due to temperature/elevation changes, and other factors that the "one map for all situations" just doesn't quite be able to work all the time.
And if the wideband takes a crap then it will revert to the main map. So this is kind of a closed loop with a 15% limit???
Thanks,
kirk
