Sending my primary off to Carls this week to get the sheaves machined, new spring, weights, and balanced. I was told to put a tension mark on the clutch before I send it. Just looking for clarification on how to do this. Im assuming I take a sharpie and just make a line from where the belt sits to the outer edge of the clutch... then what, do I just run the sled till the clutch engages? Or to a certain rpm? And also I currently have 58 gram weights in for 10-12k' but I live in eastern SD at 2000'. I will need to put my 68 weights back in to get an accurate mark? Or no? Clutch is being set up for 8-10k- if that matters. Thanks
