I have always put 2 Delrins washer together between spring and cup...splitting hairs, not a big deal regardless of where they are placed. My theory is the least friction and wear having plastic-to-plastic.
When I pulled my helix out last year there was a bunch of metal or probably aluminum shavings in there. Is this common or do I have a problem?
What I found worked well for me was to back out the deflection screw so there is no pressure on the spring and the helix comes out with little effort. Normally can do it with my fingers or at most a slight tap with a rubber mallet and then can pull it right out.
PV
I just picked up a 2012 Switchback Assault.... went to take the clutches apart and found that 3 of the 4 helix bolts are stripped, so I can't get them off. other than Easy-Outs has anyone experienced any other way of getting these things out without damaging anything?
Have your Snap-On dealer replace your conventional torx bit to the gold color bits (W). They don't twist.
Any thoughts on placing a small amount of copper anti seize on the screws before placing them back in? I'm having to buy new screws every time I go to work on secondary. $8.24 per screw is raping a guy.
I agree 100% something has changed...there's a reason we always stock 20 or so of the screws.
Thanks for the heads up Dave... I just ordered a set of these online... (local SnapOn guy is never around... and I'm small time... free ship). I got an extra T27 replacement insert just in case (FTXB27E2). Tired of the other brand I have breaking.
I'm eyeballing the new LIon 18v 3/8" cordless impact for a Christmas present to myself... Pretty darn nice!!
Thanks for posting this up. I needed some replacement Torx for my set and hard to nail down a Snap-on guy. Just ordered those heavy duty ones for my set. Thanks for the links.
